Introducción
in order to complete this guide, you will need to remove the battery, put a new one in its place, and solder the new connections onto the motherboard.
Qué necesitas
Un-stick the battery from the motherboard assembly with the plastic opening tool.
To reassemble your device, glue the new battery to where the old one was and solder the new power connectors where the old ones were. Then follow the instructions in reverse order.
3 personas más completaron esta guía.
