Guía aportada por comunidad
Un miembro increíble de nuestra comunidad escribió esta guía. No ha sido creada por el personal de iFixit.
Introducción
Ir al paso 1 ↓Often a wine cooler is replaced because of a noise problem. Often a $10 fix
Qué necesitas
Herramientas
The Cuisinart - Private Reserve 16-Bottle Wine Cellar often is replaced because the cooling fan becomes noisy.
To access the fan - unplug the unit. Remove the rear cover with a #2 phillips screw driver. Once the cover is off you will see the fan and it is held on by 4 small screws and nuts. The electrical connector location on the circuit board is labeled "fan". Carefully unplug the connector and remove the fan.
for around $10 you have a working wine cooler
8 personas más completaron esta guía.
22Guía Comentarios
You want the heat to be blown out.
Mine is a Koolatron 24 bottles dual compartments wine fridge. It is a thermoelectric model. Each compartment has two fans - one that is visible when the back is removed and the second further inside. There is a cooling module on a heat sink between the two fans. I was informed that the exterior fan must blow towards the module( drawing in room temperature air and blowing it along the “heat side” of the module) and the inside fan must blow into the fridge (drawing the cold from the “cooling side” of the module and blowing it into the fridge) Does sound correct to you?
How do I order a brushless DC fan model #9025S and from where?
thank you,
Skip M.
I had to order a replacement from the manufacturer in China. I Googled the name on the fan and found the site. I ordered 2 replacements as my cooler has 2 levels. $14 and free shipping, but it won’t be here for 2 months. You might try entering the fan specs on your search engine (brushless fan whatever volts, amps, size). I got some hits on that but the amperage was too high as I need 0.8 amps. Good luck.
