Saltar al contenido principal
Introducción
Tearing down my door alarm to see what's broken - it should beep hard but it isn't. It's a pretty fragile thing that could use some new fixation. (I didn't photograph the magnet that's next to it but it exists and the alarm stops when it is close to the device).
Partes
No se especificaron partes.
  1. This is a beautiful not-alarming alarm This is a beautiful not-alarming alarm
    • This is a beautiful not-alarming alarm
  2. There is a screw hidden underneath the adhesive strip. Screw it open to get in
    • There is a screw hidden underneath the adhesive strip. Screw it open to get in
  3. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  4. Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm) Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm)
    • Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm)
  5. The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again
    • The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again
    • This will definitely wake me up when there's someone opening my door! Fixed
Conclusión
Anke
Miembro Desde 25/04/18
123 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 25
