Qué necesitas
Resumen del Video
Broken screen ? that's a pity
You'll need hot air. Not too much thought, you'll melt the plastic otherwise
Now just pry it open SLOWLY and apply heat.
Nice, I see you've got the cover off
Disconnect the battery (not with a metal tool)
Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
Get the battery out (don't bend it too much)
Disconnect the LCD ribbon
Disconnect the cameras
Unscrew anything you see
Take the SIM trays out
Take the motherboard out. You will have to disconnect to ribbon cables
Two screws here
To take this guy out, you can use heat again
Aaaaand with more heat, you will get the screen panel out !
4 personas más completaron esta guía.
