Saltar al contenido principal
Wiko Getaway Screen Panel Replacement
Qué necesitas
Resumen del Video
  1. Wiko Getaway Screen Panel Replacement, Back cover: paso 1, imagen 1 de 3 Wiko Getaway Screen Panel Replacement, Back cover: paso 1, imagen 2 de 3 Wiko Getaway Screen Panel Replacement, Back cover: paso 1, imagen 3 de 3
    • Broken screen ? that's a pity
    • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
    • Now just pry it open SLOWLY and apply heat.
  2. Wiko Getaway Screen Panel Replacement, Disconnect stuff: paso 2, imagen 1 de 3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: paso 2, imagen 2 de 3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: paso 2, imagen 3 de 3
    • Nice, I see you've got the cover off
    • Disconnect the battery (not with a metal tool)
    • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  3. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: paso 3, imagen 1 de 3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: paso 3, imagen 2 de 3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: paso 3, imagen 3 de 3
    • Get the battery out (don't bend it too much)
    • Disconnect the LCD ribbon
    • Disconnect the cameras
  4. Wiko Getaway Screen Panel Replacement, Screws ! Finally: paso 4, imagen 1 de 3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: paso 4, imagen 2 de 3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: paso 4, imagen 3 de 3
    • Unscrew anything you see
    • Take the SIM trays out
    • Take the motherboard out. You will have to disconnect to ribbon cables
  5. Wiko Getaway Screen Panel Replacement, Final: paso 5, imagen 1 de 3 Wiko Getaway Screen Panel Replacement, Final: paso 5, imagen 2 de 3 Wiko Getaway Screen Panel Replacement, Final: paso 5, imagen 3 de 3
    • Two screws here
    • To take this guy out, you can use heat again
    • Aaaaand with more heat, you will get the screen panel out !
Conclusión
4 personas más completaron esta guía.
Alexandre Isaac
Miembro Desde 04/07/13
2,863 Reputación
8 Guías creadas
Equipo
The Repair Academy Miembro de The Repair Academy
Business
1 Miembro
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 2,094
