Saltar al contenido principal
Wii U GamePad Outer Case Replacement
Qué necesitas
  1. Wii U GamePad Outer Case Replacement, Battery: paso 1, imagen 1 de 2 Wii U GamePad Outer Case Replacement, Battery: paso 1, imagen 2 de 2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Outer Case Replacement: paso 2, imagen 1 de 3 Wii U GamePad Outer Case Replacement: paso 2, imagen 2 de 3 Wii U GamePad Outer Case Replacement: paso 2, imagen 3 de 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Outer Case Replacement, Outer Case: paso 3, imagen 1 de 3 Wii U GamePad Outer Case Replacement, Outer Case: paso 3, imagen 2 de 3 Wii U GamePad Outer Case Replacement, Outer Case: paso 3, imagen 3 de 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Outer Case Replacement: paso 4, imagen 1 de 2 Wii U GamePad Outer Case Replacement: paso 4, imagen 2 de 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
Conclusión
11 personas más completaron esta guía.
Kim Arre
Miembro Desde 01/11/13
4,918 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 17-20, Forte Winter 2013 Miembro de Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Miembros
38 Guías creadas
2 comentarios
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 25
Ultimos 30 días: 117
Todo El Tiempo: 14,576
