Introducción
This guide will help you to replace your camera. For this replacement, you will need to use tweezers.
Partes
No se especificaron partes.
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
Remove the white flex cable with the tweezers.
Flip motherboard over.
Remove the metal housing around the camera with tweezers.
