Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide will help you to remove the bluetooth board from the Nintendo Wii U Gamepad.
  1. Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Lift and remove the battery plate.
    • Lift and remove the battery plate.
  3. With your finger, press down and pull back on the battery connector plug. Remove the battery from the battery case. Remove the battery from the battery case.
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  5. Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case. Lift up on the back of case. Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  6. Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
  7. Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer. Remove the white flex cable with the tweezers. Remove the white flex cable with the tweezers.
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  8. With your fingers,  lift and remove bluetooth board. Remove the board carefully as there are still two wires attached.
    • With your fingers, lift and remove bluetooth board.
    • Remove the board carefully as there are still two wires attached.
  9. Disconnect the black and white wires off of the back of the bluetooth module. Disconnect the black and white wires off of the back of the bluetooth module.
    • Disconnect the black and white wires off of the back of the bluetooth module.
  10. Lift and remove the bluetooth module.
    • Lift and remove the bluetooth module.
Conclusión
15 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-6, Sullivan Spring 2016 Miembro de USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Miembros
14 Guías creadas
I just completed this repair on our Game Pad, and it worked perfectly!
There were two things that I noted that may be of use to anyone else completing this repair. First, the 9mm screws on the back may be located under small stickers used to conceal the screw holes. If you take them up carefully with a knife or other flat blade, you can reuse them if desired. Second, I didn’t see the need to remove the white ribbon cable in step #6. I successfully completed the repair without that step.
DarrinGrimm - Contestar
I just completed this repair on our Game Pad, and the guide worked perfectly!
There were two things that I noticed that may be of help to someone else completing this repair. First, note that the 9mm screws holding the back on may be located under small black stickers used to hide the screw holes. If you take them up carefully with a knife or other flat blade, you should be able to reuse them if you desire. Second, I didn’t see a need to remove the white ribbon cable in Step #6. I successfully completed the repair without that step.
Cheers!
This fix worked perfectly - our Wii U was virtually unusable because of the severely limited range of the gamepad. My kids are thrilled that they can comfortably play again!
Bill Jones - Contestar
Worked perfectly, gamepad only worked within 2 ft of the console and now works 15ft away.
Instructions were concise, well illustrated and easy to complete.
Thanks a lot!
Peter Grubb - Contestar
I went to do this - already have another chip - but I discovered there are no wires attached! The white and black wires shown are not in my gamepad at all. I’m amazed I can connect in the first place. Any idea how I can replace the wires that attach to the chip? Or work around it?
Alexander Albert - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 72
Ultimos 30 días: 253
Todo El Tiempo: 9,622
