Saltar al contenido principal
Wii Balance Board Front Cover Replacement
Qué necesitas
  1. Wii Balance Board Front Cover Replacement, Unscrewing the Foot Cover: paso 1, imagen 1 de 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Front Cover Replacement, Removing the Foot Cover: paso 2, imagen 1 de 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Front Cover Replacement, Removing the Foot: paso 3, imagen 1 de 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Front Cover Replacement, Removing the Additional Feet: paso 4, imagen 1 de 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Front Cover Replacement, Unscrewing the Back Cover: paso 5, imagen 1 de 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Front Cover Replacement, Removing the Back Cover: paso 6, imagen 1 de 1
    • Lift off the gray back cover.
  7. Wii Balance Board Front Cover Replacement, Battery Compartment: paso 7, imagen 1 de 2 Wii Balance Board Front Cover Replacement, Battery Compartment: paso 7, imagen 2 de 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Front Cover Replacement, Removing the Battery Case: paso 8, imagen 1 de 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Wii Balance Board Front Cover Replacement, Unscrewing the Frame: paso 9, imagen 1 de 1
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Front Cover Replacement, Removing the Frame: paso 10, imagen 1 de 1
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
Conclusión
Una persona más ha completado esta guía.
Cory Olson
Miembro Desde 09/29/14
858 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-8, Forte Fall 2014 Miembro de Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 1,210
