Introducción
This guide will demonstrate how to replace the Front Cover of the Wii Balance Board.
Qué necesitas
Flip device upside-down so the plastic white board is facing the ground.
Locate the four feet in the corners of the Balance Board.
Unscrew the three 12.7 mm Phillips screws from each foot cover.
Remove the gray plastic ring from the actual foot by lifting it up.
Locate the gray battery compartment.
Push the tab on the bottom and lift up completely to remove the cover to the batteries.
Unscrew the two 6.35 mm Phillips #1 screws.
Slide the battery case out.
Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
Una persona más ha completado esta guía.
