Saltar al contenido principal
Wii Balance Board Frame Replacement
Qué necesitas
  1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: paso 1, imagen 1 de 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Frame Replacement, Removing the Foot Cover: paso 2, imagen 1 de 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Frame Replacement, Removing the Foot: paso 3, imagen 1 de 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Frame Replacement, Removing the Additional Feet: paso 4, imagen 1 de 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: paso 5, imagen 1 de 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Frame Replacement, Removing the Back Cover: paso 6, imagen 1 de 1
    • Lift off the gray back cover.
  7. Wii Balance Board Frame Replacement, Battery Compartment: paso 7, imagen 1 de 2 Wii Balance Board Frame Replacement, Battery Compartment: paso 7, imagen 2 de 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Frame Replacement, Removing the Battery Case: paso 8, imagen 1 de 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Wii Balance Board Frame Replacement, Unscrewing the Frame: paso 9, imagen 1 de 1
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Frame Replacement, Removing the Frame: paso 10, imagen 1 de 1
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
  11. Wii Balance Board Frame Replacement, Removing the Power Supply: paso 11, imagen 1 de 1
    • Lift out the power supply. It is not screwed in.
Conclusión
Una persona más ha completado esta guía.
Cory Olson
Miembro Desde 09/29/14
891 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-8, Forte Fall 2014 Miembro de Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Miembros
15 Guías creadas
Un comentario
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Dominik - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 2,922
