Saltar al contenido principal
Wii Balance Board Foot Replacement
Qué necesitas
  1. Wii Balance Board Foot Replacement, Unscrewing the Foot Cover: paso 1, imagen 1 de 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Foot Replacement, Removing the Foot Cover: paso 2, imagen 1 de 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Foot Replacement, Removing the Foot: paso 3, imagen 1 de 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Foot Replacement, Removing the Additional Feet: paso 4, imagen 1 de 1
    • Repeat steps two and three on the remaining four feet.
Conclusión
Cory Olson
Miembro Desde 09/29/14
858 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-8, Forte Fall 2014 Miembro de Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Miembros
15 Guías creadas
2 comentarios
I am in need of a foot cover. Where can I find one??
Marvin Hopper - Contestar
This manual did not help
nbrown1959.nb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 2,590
