Saltar al contenido principal
Wii Balance Board Battery Case Replacement
Qué necesitas
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: paso 1, imagen 1 de 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: paso 2, imagen 1 de 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: paso 3, imagen 1 de 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: paso 4, imagen 1 de 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: paso 5, imagen 1 de 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: paso 6, imagen 1 de 1
    • Lift off the gray back cover.
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: paso 7, imagen 1 de 2 Wii Balance Board Battery Case Replacement, Battery Compartment: paso 7, imagen 2 de 2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: paso 8, imagen 1 de 1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
Conclusión
16 personas más completaron esta guía.
Equipo
Cal Poly, Team 13-8, Forte Fall 2014 Miembro de Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Miembros
15 Guías creadas
13 comentarios
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - Contestar
Then what do you do after you remove the battery case?
CRAIG WIKMAN - Contestar
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - Contestar
u rock - it totally worked
scottydecept - Contestar
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 40
Ultimos 30 días: 239
Todo El Tiempo: 38,697
