Saltar al contenido principal
Wii Balance Board Back Cover Replacement
Qué necesitas
  1. Wii Balance Board Back Cover Replacement, Unscrewing the Foot Cover: paso 1, imagen 1 de 1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Back Cover Replacement, Removing the Foot Cover: paso 2, imagen 1 de 1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Back Cover Replacement, Removing the Foot: paso 3, imagen 1 de 1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Back Cover Replacement, Removing the Additional Feet: paso 4, imagen 1 de 1
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Back Cover Replacement, Unscrewing the Back Cover: paso 5, imagen 1 de 1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Back Cover Replacement, Removing the Back Cover: paso 6, imagen 1 de 1
    • Lift off the gray back cover.
Conclusión
Cory Olson
Miembro Desde 09/29/14
858 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-8, Forte Fall 2014 Miembro de Cal Poly, Team 13-8, Forte Fall 2014
CPSU-FORTE-F14S13G8
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 876
