Saltar al contenido principal
Why! NH57ADS Motherboard Replacement
Qué necesitas
  1. Why! NH57ADS Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS Motherboard Replacement, Bottom Cover: paso 2, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Bottom Cover: paso 2, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Bottom Cover: paso 2, imagen 3 de 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS Motherboard Replacement, Removing the Bottom Cover: paso 3, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Removing the Bottom Cover: paso 3, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Removing the Bottom Cover: paso 3, imagen 3 de 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS Motherboard Replacement, Keyboard: paso 4, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Keyboard: paso 4, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Remove the two Phillips screws with the keypad symbol next to them.
    • Insert an opening pick into the upper slot of the keyboard and slide it to the end.
  5. Why! NH57ADS Motherboard Replacement, Remove the Keyboard: paso 5, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Remove the Keyboard: paso 5, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Remove the Keyboard: paso 5, imagen 3 de 3
    • Carefully lift the keyboard.
    • Flip up the retaining latch on the black keyboard cable and slide it out of the connector.
    • Repeat with the orange backlight cable.
  6. Why! NH57ADS Motherboard Replacement, Fan: paso 6, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Fan: paso 6, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Fan: paso 6, imagen 3 de 3
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  7. Why! NH57ADS Motherboard Replacement, Fan and Heatsink Assembly: paso 7, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Fan and Heatsink Assembly: paso 7, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Fan and Heatsink Assembly: paso 7, imagen 3 de 3
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
  8. Why! NH57ADS Motherboard Replacement, CPU: paso 8, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, CPU: paso 8, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, CPU: paso 8, imagen 3 de 3
    • Carefully pull the metal bar away from the processor to free it from under the retaining tab, then lift it to release the processor pins.
    • Gently remove the processor by lifting it straight up.
  9. Why! NH57ADS Motherboard Replacement, Bottom Case: paso 9, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Bottom Case: paso 9, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Bottom Case: paso 9, imagen 3 de 3
    • Remove the 12 Phillips screws securing the bottom case.
    • Using an opening pick, detach the lower case.
  10. Why! NH57ADS Motherboard Replacement, Motherboard: paso 10, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Motherboard: paso 10, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Motherboard: paso 10, imagen 3 de 3
    • Lift the retaining latches and remove the two ribbon cables located under the keyboard.
    • Remove the two remaining Phillips screws securing the motherboard.
    • Carefully unplug the two speaker cables using fingernails of fine tip tweezers. Do not pull on the delicate wires, as they can break easily.
    • Flip up the retaining latch on the ZIF connector between the speaker connector and the mounting screw. Remove the flex cable from the connector.
  11. Why! NH57ADS Motherboard Replacement, Disconnect Cables: paso 11, imagen 1 de 3 Why! NH57ADS Motherboard Replacement, Disconnect Cables: paso 11, imagen 2 de 3 Why! NH57ADS Motherboard Replacement, Disconnect Cables: paso 11, imagen 3 de 3
    • Unplug the LCD cable by grasping the tab and pulling it straight up. Unplug the other display cable by pulling it in the direction of the arrow. Press it out by the connector, not the cable.
    • Carefully lift the motherboard to access the remaining cable attached to the bottom side of the board.
  12. Why! NH57ADS Motherboard Replacement: paso 12, imagen 1 de 3 Why! NH57ADS Motherboard Replacement: paso 12, imagen 2 de 3 Why! NH57ADS Motherboard Replacement: paso 12, imagen 3 de 3
    • Lift the black retaining latch on the ZIF connector and unplug the flex cable.
    • The motherboard has now been removed.
Conclusión
To reassemble your device, follow the instructions in reverse order.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ Jerry Wheeler nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
244 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 85
