Saltar al contenido principal
Esta traducción podría no reflejar los cambios más recientes añadidos a la guía de referencia. Ayúdanos a actualizar la traducción o revisa la guía original.
Why! NH57ADS CPU Replacement
Qué necesitas
  1. Why! NH57ADS CPU Replacement, Battery: paso 1, imagen 1 de 3 Why! NH57ADS CPU Replacement, Battery: paso 1, imagen 2 de 3 Why! NH57ADS CPU Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS CPU Replacement, Bottom Cover: paso 2, imagen 1 de 3 Why! NH57ADS CPU Replacement, Bottom Cover: paso 2, imagen 2 de 3 Why! NH57ADS CPU Replacement, Bottom Cover: paso 2, imagen 3 de 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS CPU Replacement, Removing the Bottom Cover: paso 3, imagen 1 de 3 Why! NH57ADS CPU Replacement, Removing the Bottom Cover: paso 3, imagen 2 de 3 Why! NH57ADS CPU Replacement, Removing the Bottom Cover: paso 3, imagen 3 de 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS CPU Replacement, Fan: paso 4, imagen 1 de 3 Why! NH57ADS CPU Replacement, Fan: paso 4, imagen 2 de 3 Why! NH57ADS CPU Replacement, Fan: paso 4, imagen 3 de 3
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  5. Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: paso 5, imagen 1 de 3 Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: paso 5, imagen 2 de 3 Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: paso 5, imagen 3 de 3
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
  6. Why! NH57ADS CPU Replacement, CPU: paso 6, imagen 1 de 3 Why! NH57ADS CPU Replacement, CPU: paso 6, imagen 2 de 3 Why! NH57ADS CPU Replacement, CPU: paso 6, imagen 3 de 3
    • Carefully pull the metal bar away from the processor to free it from under the retaining tab, then lift it to release the processor pins.
    • Gently remove the processor by lifting it straight up.
Conclusión
To reassemble your device, follow the instructions in reverse order.
Un agradecimiento especial a estos traductores:
fr en
50%
¡ Jerry Wheeler nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
244 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 59
