Saltar al contenido principal
Whirlpool Refrigerator Freezer Door Replacement
Qué necesitas
  1. Whirlpool Refrigerator Freezer Door Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Door Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: paso 3, imagen 1 de 3 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: paso 3, imagen 2 de 3 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: paso 3, imagen 3 de 3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: paso 4, imagen 1 de 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: paso 4, imagen 2 de 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: paso 4, imagen 3 de 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: paso 5, imagen 1 de 2 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: paso 5, imagen 2 de 2
    • Remove the screw(s) securing the freezer door wiring harness.
    • Remove the screw(s) securing the freezer door water hose.
  6. Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: paso 6, imagen 1 de 2 Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: paso 6, imagen 2 de 2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: paso 7, imagen 1 de 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: paso 7, imagen 2 de 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: paso 7, imagen 3 de 3
    • Disconnect any connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Freezer Door Replacement: paso 8, imagen 1 de 1
    • Place a clean cloth under the water hose before continuing.
  9. Whirlpool Refrigerator Freezer Door Replacement: paso 9, imagen 1 de 2 Whirlpool Refrigerator Freezer Door Replacement: paso 9, imagen 2 de 2
    • Pull the plastic clip off the freezer door water hose.
  10. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: paso 10, imagen 1 de 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: paso 10, imagen 2 de 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: paso 10, imagen 3 de 3
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the water tube out of its slot.
  11. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: paso 11, imagen 1 de 2 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: paso 11, imagen 2 de 2
    • Depending on your device, you may have a plastic cover on the hinge. Remove it before continuing.
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Remove the screw(s) securing the freezer door.
    • Some devices may have screws solely for alignment. You don't need to remove these.
  12. Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: paso 12, imagen 1 de 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: paso 12, imagen 2 de 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: paso 12, imagen 3 de 3
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: paso 13, imagen 1 de 3 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: paso 13, imagen 2 de 3 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: paso 13, imagen 3 de 3
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. Whirlpool Refrigerator Freezer Door Replacement, Remove the door: paso 14, imagen 1 de 2 Whirlpool Refrigerator Freezer Door Replacement, Remove the door: paso 14, imagen 2 de 2
    • You're now left with the freezer door.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,885 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
30 Miembros
509 Guías creadas
Un comentario
There is a pending class action suit about this defect: https://chimicles.com/whirlpool-refriger...
Barbara Hoover - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 21
Ultimos 30 días: 65
Todo El Tiempo: 1,049
