Saltar al contenido principal
Whirlpool Refrigerator Drain Pan Replacement
Qué necesitas
  1. Whirlpool Refrigerator Drain Pan Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Drain Pan Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: paso 3, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: paso 3, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: paso 3, imagen 3 de 3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: paso 4, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: paso 4, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: paso 4, imagen 3 de 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the wiring harness: paso 5, imagen 1 de 1
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the wiring harness.
  6. Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: paso 6, imagen 1 de 2 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: paso 6, imagen 2 de 2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: paso 7, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: paso 7, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: paso 7, imagen 3 de 3
    • Disconnect the two connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: paso 8, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: paso 8, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: paso 8, imagen 3 de 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  9. Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: paso 9, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: paso 9, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: paso 9, imagen 3 de 3
    • Pull the rear panel off the chassis to remove it.
  10. Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: paso 10, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: paso 10, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: paso 10, imagen 3 de 3
    • Put on gloves before continuing, as the sheet metal and the condenser fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  11. Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: paso 11, imagen 1 de 2 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: paso 11, imagen 2 de 2
    • Use a flathead screwdriver, or a similar tool, to pry up the metal clip from the back of the drain pan.
  12. Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: paso 12, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: paso 12, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: paso 12, imagen 3 de 3
    • Pull the wiring harness straight out of the chassis until you can access the drain pan.
  13. Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: paso 13, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: paso 13, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: paso 13, imagen 3 de 3
    • Peel the tape off the front metal clip attached to the drain pan.
  14. Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: paso 14, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: paso 14, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: paso 14, imagen 3 de 3
    • Use your fingers to release the metal clip on the front of the drain pan.
    • Fold the metal clip so that it lays flat on the floor of the chassis.
  15. Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: paso 15, imagen 1 de 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: paso 15, imagen 2 de 3 Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: paso 15, imagen 3 de 3
    • Pull the drain pan toward the front of the chassis to release any remaining clips.
    • Remove the drain pan.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,885 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
30 Miembros
509 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 79
Ultimos 30 días: 328
Todo El Tiempo: 2,828
