Saltar al contenido principal
Whirlpool Refrigerator Dispenser Assembly Replacement
Qué necesitas
  1. Whirlpool Refrigerator Dispenser Assembly Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the dispenser panels: paso 2, imagen 1 de 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the dispenser panels: paso 2, imagen 2 de 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: paso 3, imagen 1 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: paso 3, imagen 2 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: paso 3, imagen 3 de 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the control board: paso 4, imagen 1 de 1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Dispenser Assembly Replacement: paso 5, imagen 1 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement: paso 5, imagen 2 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement: paso 5, imagen 3 de 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: paso 6, imagen 1 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: paso 6, imagen 2 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: paso 6, imagen 3 de 3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the control board: paso 7, imagen 1 de 1
    • Remove the control board.
  8. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: paso 8, imagen 1 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: paso 8, imagen 2 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: paso 8, imagen 3 de 3
    • Use a flathead screwdriver, or a similar tool, to pry up the plastic clip securing the water hose.
    • Remove the plastic clip.
  9. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: paso 9, imagen 1 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: paso 9, imagen 2 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: paso 9, imagen 3 de 3
    • Use a flathead screwdriver, or a similar tool, to pry up the water hose enough to grip it with your fingers.
    • Pull the water hose straight up to disconnect it.
  10. Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the cables: paso 10, imagen 1 de 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the cables: paso 10, imagen 2 de 2
    • Reposition the cables so they lay in front of the top plastic clip.
  11. Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: paso 11, imagen 1 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: paso 11, imagen 2 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: paso 11, imagen 3 de 3
    • Depending on your device, the amount of plastic clips that secure the dispenser assembly can vary.
    • Use a flathead screwdriver, or a similar tool, to press the plastic clip toward the dispenser assembly.
    • Repeat for the other plastic clips to completely separate the dispenser assembly from the chassis.
  12. Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the dispenser assembly: paso 12, imagen 1 de 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the dispenser assembly: paso 12, imagen 2 de 2
    • Pull the dispenser assembly away from the chassis enough to access its connectors.
  13. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: paso 13, imagen 1 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: paso 13, imagen 2 de 3 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: paso 13, imagen 3 de 3
    • While performing this step, support the dispenser assembly so it doesn't fall.
    • Disconnect the connector attached to the dispenser assembly.
  14. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser assembly: paso 14, imagen 1 de 1
    • Remove the dispenser assembly.
  15. Whirlpool Refrigerator Dispenser Assembly Replacement, Meter the dispenser assembly: paso 15, imagen 1 de 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Meter the dispenser assembly: paso 15, imagen 2 de 2
    • If you own a multimeter, you can test your solenoid's resistance.
    • With the button in its neutral position, the multimeter should read "open circuit" or "OL."
    • With the button pressed, the multimeter should read close to 0Ω.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,885 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
30 Miembros
509 Guías creadas
2 comentarios
The bottom side of refrigeration is not working but the top inversely working the cooling process
Dawit Muluneh - Contestar
I'd take a look at one of two troubleshooting pages:
Freezer Not Freezing or Refrigerator Not Cooling
nicO -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 135
Todo El Tiempo: 852
