Saltar al contenido principal
Whirlpool Electric Range Oven Light Replacement
Qué necesitas
  1. Whirlpool Electric Range Oven Light Replacement, Oven Light: paso 1, imagen 1 de 1
    • Disconnect the oven from the power source.
    • Not removing the plug from the power could cause injuries or be fatal.
  2. Whirlpool Electric Range Oven Light Replacement: paso 2, imagen 1 de 1
    • Remove the oven racks for better movement.
  3. Whirlpool Electric Range Oven Light Replacement: paso 3, imagen 1 de 1
    • Remove the glass bulb covering by rotating it counterclockwise.
    • The bulb coverings look like little jars. There may be multiple bulbs in the back or side of the oven.
  4. Whirlpool Electric Range Oven Light Replacement: paso 4, imagen 1 de 1
    • Unscrew the bulb in a counterclockwise manner.
  5. Whirlpool Electric Range Oven Light Replacement: paso 5, imagen 1 de 1
    • Insert the new bulb in by rotating it in a clockwise manner.
  6. Whirlpool Electric Range Oven Light Replacement: paso 6, imagen 1 de 1
    • Screw the glass bulb covering back on in a clockwise manner.
  7. Whirlpool Electric Range Oven Light Replacement: paso 7, imagen 1 de 1
    • Reinsert the oven racks.
  8. Whirlpool Electric Range Oven Light Replacement: paso 8, imagen 1 de 1
    • Plug the outlet back in to the power source.
Linea de Meta
Kevin Patel
Miembro Desde 03/23/21
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 65
Todo El Tiempo: 3,368
