Saltar al contenido principal
Wexford CT-166TF Air Filter Casing Replacement
Qué necesitas
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: paso 1, imagen 1 de 1
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: paso 2, imagen 1 de 3 Wexford CT-166TF Air Filter Casing Replacement: paso 2, imagen 2 de 3 Wexford CT-166TF Air Filter Casing Replacement: paso 2, imagen 3 de 3
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: paso 3, imagen 1 de 1
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: paso 4, imagen 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: paso 4, imagen 2 de 2
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: paso 5, imagen 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: paso 5, imagen 2 de 2
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: paso 6, imagen 1 de 1
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: paso 7, imagen 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: paso 7, imagen 2 de 2
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: paso 8, imagen 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: paso 8, imagen 2 de 2
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: paso 9, imagen 1 de 1
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: paso 10, imagen 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: paso 10, imagen 2 de 2
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
Conclusión
Una persona más ha completado esta guía.
Dannis Thompson
Miembro Desde 04/10/17
261 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S3-G4, Liner Spring 2017 Miembro de UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 630
