Saltar al contenido principal
Western Digital My Book Mini USB Port Replacement
Qué necesitas
  1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: paso 1, imagen 1 de 3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: paso 1, imagen 2 de 3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: paso 1, imagen 3 de 3
    • Start by turning the device port side up.
    • With the plastic opening tool, pry along the edges of the case.
    • When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
  2. Western Digital My Book Mini USB Port Replacement: paso 2, imagen 1 de 1
    • Gently pull the three pronged, clear plastic piece from the rubber holder.
  3. Western Digital My Book Mini USB Port Replacement: paso 3, imagen 1 de 1
    • Unscrew the two screws from the motherboard.
  4. Western Digital My Book Mini USB Port Replacement: paso 4, imagen 1 de 1
    • Remove all the rubber pieces from the four corners to unhinge the motherboard.
  5. Western Digital My Book Mini USB Port Replacement: paso 5, imagen 1 de 1
    • Remove the motherboard.
    • Set aside in a safe anti-static location.
  6. Western Digital My Book Mini USB Port Replacement: paso 6, imagen 1 de 1
    • Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
  7. Western Digital My Book Mini USB Port Replacement: paso 7, imagen 1 de 1
    • Soldering irons can get HOT! Do not touch the iron tip, make sure it cools down for a good 30 minutes before touching the tip.
    • Start heating up the Soldering Iron, may take about 10–15 mins.
  8. Western Digital My Book Mini USB Port Replacement: paso 8, imagen 1 de 1
    • Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
    • Make sure the USB is firmly attached to the motherboard.
Conclusión
To reassemble your device, follow these instructions in reverse order from step 8.
8 personas más completaron esta guía.
Gabriel Rael
Miembro Desde 06/24/15
333 Reputación
1 Guía escrita
Equipo
Colorado Springs, Team 1-2, Mcmichael SU 2015 Miembro de Colorado Springs, Team 1-2, Mcmichael SU 2015
UCCS-MCMICHAEL-SU15S1G2
Miembros de 2
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 45
Todo El Tiempo: 17,408
