Saltar al contenido principal
Westcott iPoint Evolution Outer Casing Replacement
Qué necesitas
  1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: paso 1, imagen 1 de 1
    • Step 1: Start with the back of the pencil sharpener facing you.
    • This allows you to locate the power source.
  2. Westcott iPoint Evolution Outer Casing Replacement: paso 2, imagen 1 de 1
    • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
  3. Westcott iPoint Evolution Outer Casing Replacement: paso 3, imagen 1 de 2 Westcott iPoint Evolution Outer Casing Replacement: paso 3, imagen 2 de 2
    • There are three parts of the sharpener.
    • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
  4. Westcott iPoint Evolution Outer Casing Replacement: paso 4, imagen 1 de 3 Westcott iPoint Evolution Outer Casing Replacement: paso 4, imagen 2 de 3 Westcott iPoint Evolution Outer Casing Replacement: paso 4, imagen 3 de 3
    • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
  5. Westcott iPoint Evolution Outer Casing Replacement: paso 5, imagen 1 de 3 Westcott iPoint Evolution Outer Casing Replacement: paso 5, imagen 2 de 3 Westcott iPoint Evolution Outer Casing Replacement: paso 5, imagen 3 de 3
    • Step 5: Remove the small ring that is around the sharpener.
    • This piece is below the center of the sharpener that you just removed.
  6. Westcott iPoint Evolution Outer Casing Replacement: paso 6, imagen 1 de 1
    • Step 6: Flip the pencil sharpener upside down.
    • Locate the four screws on the bottom of the sharpener.
  7. Westcott iPoint Evolution Outer Casing Replacement: paso 7, imagen 1 de 1
    • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
  8. Westcott iPoint Evolution Outer Casing Replacement: paso 8, imagen 1 de 1
    • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
  9. Westcott iPoint Evolution Outer Casing Replacement: paso 9, imagen 1 de 1
    • Step 9: Carefully lift the lid off of the sharpener.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 43
Todo El Tiempo: 11,707
