Saltar al contenido principal
Wen 2307 Speed Adjustment Assembly Replacement
Qué necesitas
  1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: paso 1, imagen 1 de 1
    • Unscrew the locking sleeve.
  2. Wen 2307 Speed Adjustment Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the hanging clip.
  3. Wen 2307 Speed Adjustment Assembly Replacement: paso 3, imagen 1 de 2 Wen 2307 Speed Adjustment Assembly Replacement: paso 3, imagen 2 de 2
    • Unscrew the six 8mm PH2 screws.
  4. Wen 2307 Speed Adjustment Assembly Replacement: paso 4, imagen 1 de 1
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Wen 2307 Speed Adjustment Assembly Replacement: paso 5, imagen 1 de 1
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  6. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: paso 6, imagen 1 de 2 Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: paso 6, imagen 2 de 2
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
  7. Wen 2307 Speed Adjustment Assembly Replacement: paso 7, imagen 1 de 1
    • Remove the place boar carefully.
  8. Wen 2307 Speed Adjustment Assembly Replacement: paso 8, imagen 1 de 1
    • Pull out the power cable connectors.
  9. Wen 2307 Speed Adjustment Assembly Replacement: paso 9, imagen 1 de 1
    • Pull out the cord sleve for the new cable replacement.
  10. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: paso 10, imagen 1 de 1
    • Remove the connected wiring from the circuit board.
  11. Wen 2307 Speed Adjustment Assembly Replacement: paso 11, imagen 1 de 1
    • Remove the single 4mm screw retaining the circuit board.
  12. Wen 2307 Speed Adjustment Assembly Replacement: paso 12, imagen 1 de 1
    • Gently pry the circuit board from the back piece.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 12-1, Eyestone Spring 2016 Miembro de USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 722
