Saltar al contenido principal
Introducción
Use this guide to replace a broken or non-functioning LCD in your Welch Allyn 6000 series Connex vital signs monitor.
PLEASE NOTE: This repair guide was developed by the iFixit team based on Welch Allyn's own service manual. Neither iFixit nor this repair guide is endorsed by or affiliated with Welch Allyn.
  1. Unplug the AC power connection cable. Unplug the AC power connection cable.
    • Unplug the AC power connection cable.
  2. Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases. Always grasp the hose by the connector. Do not pull on the hose itself. Pull the connector away from the connector port.
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases. Always grasp the cable by the connector. Do not pull on the cable itself. Pull the connector away from the connector port.
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Grasp the temperature probe and pull it up to remove it from the monitor. Grasp the temperature probe and pull it up to remove it from the monitor.
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Remove the cover of the temperature module by pressing the tab and sliding the cover to the right. Remove the cover of the temperature module by pressing the tab and sliding the cover to the right. Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port. Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port. Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Remove the flathead screw on the USB networking door.
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Holding the monitor securely, open the USB networking door.
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Detach any accessory USB cables from USB ports on the monitor. Detach any accessory USB cables from USB ports on the monitor.
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Slide the monitor off of the stand tray. Slide the monitor off of the stand tray. Slide the monitor off of the stand tray.
    • Slide the monitor off of the stand tray.
  11. Place the monitor upside down on a clean surface. Insert a coin into the slot and push to open. Choose a coin that fits comfortably into the slot.
    • Place the monitor upside down on a clean surface.
    • Insert a coin into the slot and push to open.
    • Choose a coin that fits comfortably into the slot.
    • Remove the battery cover.
  12. Use the plastic label to remove the battery from its recess. Use the plastic label to remove the battery from its recess. Use the plastic label to remove the battery from its recess.
    • Use the plastic label to remove the battery from its recess.
  13. Open the communications door to access the lower left-hand rear housing screw. Remove the four Phillips #2 screws (labeled 14 in the service manual) from the rear housing.
    • Open the communications door to access the lower left-hand rear housing screw.
    • Remove the four Phillips #2 screws (labeled 14 in the service manual) from the rear housing.
  14. With the handle/alert bar facing you, begin to lift the rear housing from the left side, holding the right side securely. Do not attempt to separate the rear housing from the monitor, it is still attached with several cables.
    • With the handle/alert bar facing you, begin to lift the rear housing from the left side, holding the right side securely.
    • Do not attempt to separate the rear housing from the monitor, it is still attached with several cables.
  15. Support the rear housing while you disconnect the cables in the following steps.
    • Support the rear housing while you disconnect the cables in the following steps.
  16. Disconnect the fan cable (labeled connector A in the service manual) from its socket in the power supply. Disconnect the fan cable (labeled connector A in the service manual) from its socket in the power supply. Disconnect the fan cable (labeled connector A in the service manual) from its socket in the power supply.
    • Disconnect the fan cable (labeled connector A in the service manual) from its socket in the power supply.
  17. Unplug the small USB connector from its socket (labeled J4 in the service manual). Unplug the small USB connector from its socket (labeled J4 in the service manual). Unplug the small USB connector from its socket (labeled J4 in the service manual).
    • Unplug the small USB connector from its socket (labeled J4 in the service manual).
  18. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  19. Disconnect the communications power cable from its socket (labeled J50 in the service manual). Only pull on the connector itself and not the socket. This connection is very tight, work the connector slowly and gently. Only pull on the connector itself and not the socket. This connection is very tight, work the connector slowly and gently.
    • Disconnect the communications power cable from its socket (labeled J50 in the service manual).
    • Only pull on the connector itself and not the socket. This connection is very tight, work the connector slowly and gently.
  20. Unplug the large USB connector from its socket (labeled J8 in the service manual). Unplug the large USB connector from its socket (labeled J8 in the service manual). Unplug the large USB connector from its socket (labeled J8 in the service manual).
    • Unplug the large USB connector from its socket (labeled J8 in the service manual).
  21. Press the tab on the ethernet cable and unplug it from its socket (labeled J9 in the service manual). Press the tab on the ethernet cable and unplug it from its socket (labeled J9 in the service manual). Press the tab on the ethernet cable and unplug it from its socket (labeled J9 in the service manual).
    • Press the tab on the ethernet cable and unplug it from its socket (labeled J9 in the service manual).
  22. The following connector requires two hands to disconnect. Flip the rear case over, and lay it on its back to gain access to the power supply cable.
    • The following connector requires two hands to disconnect. Flip the rear case over, and lay it on its back to gain access to the power supply cable.
  23. The power supply cable is secured by an interlocking connector that must be held open to unplug the connector. Insert the flat end of a spudger down into the power supply cover between the socket clip and the power supply connector. Insert the flat end of a spudger down into the power supply cover between the socket clip and the power supply connector.
    • The power supply cable is secured by an interlocking connector that must be held open to unplug the connector.
    • Insert the flat end of a spudger down into the power supply cover between the socket clip and the power supply connector.
  24. Grasp the power supply cable firmly and lift both it and the spudger from the channel in the power supply housing to unplug the connector. Grasp the power supply cable firmly and lift both it and the spudger from the channel in the power supply housing to unplug the connector. Grasp the power supply cable firmly and lift both it and the spudger from the channel in the power supply housing to unplug the connector.
    • Grasp the power supply cable firmly and lift both it and the spudger from the channel in the power supply housing to unplug the connector.
  25. Remove all USB connectors from their ports on the motherboard. Note the USB locations before removal for ease of reassembly. The locations of the USB as seen in the manual are shown in the third image. Your unit may differ depending on options. Note the USB locations before removal for ease of reassembly. The locations of the USB as seen in the manual are shown in the third image. Your unit may differ depending on options.
    • Remove all USB connectors from their ports on the motherboard.
    • Note the USB locations before removal for ease of reassembly. The locations of the USB as seen in the manual are shown in the third image. Your unit may differ depending on options.
  26. Fold the USB cable bundle out of the way. When reassembling, position each cable to extend approximately 1.5 inches past the separator as shown.
    • Fold the USB cable bundle out of the way.
    • When reassembling, position each cable to extend approximately 1.5 inches past the separator as shown.
  27. Use the flat end of a spudger to "walk" the LCD cable connector (labeled J19 in the service manual) out of its socket. Press first on one side of the connector, then the other to push it free. Be sure to press the connector itself, not the socket on the motherboard. Pull the cable straight out of its socket.
    • Use the flat end of a spudger to "walk" the LCD cable connector (labeled J19 in the service manual) out of its socket.
    • Press first on one side of the connector, then the other to push it free. Be sure to press the connector itself, not the socket on the motherboard.
    • Pull the cable straight out of its socket.
  28. Pinch the fan cable connector (labeled J45 in the service manual) and pull straight up to remove it from its socket. Be sure to pull only on the connector itself, not the socket on the motherboard. Be sure to pull only on the connector itself, not the socket on the motherboard.
    • Pinch the fan cable connector (labeled J45 in the service manual) and pull straight up to remove it from its socket.
    • Be sure to pull only on the connector itself, not the socket on the motherboard.
  29. Pull the light bar cable connector (labeled J46 in the service manual) straight up out of its socket. Pull the light bar cable connector (labeled J46 in the service manual) straight up out of its socket. Pull the light bar cable connector (labeled J46 in the service manual) straight up out of its socket.
    • Pull the light bar cable connector (labeled J46 in the service manual) straight up out of its socket.
  30. Remove the communications board cable connector from its socket (labeled J49 in the service manual). If you have a printer unit in your model, remove the printer power cable at this time,  it is labeled J17 in the service manual. If you have a printer unit in your model, remove the printer power cable at this time,  it is labeled J17 in the service manual.
    • Remove the communications board cable connector from its socket (labeled J49 in the service manual).
    • If you have a printer unit in your model, remove the printer power cable at this time, it is labeled J17 in the service manual.
  31. Carefully remove the speaker cable connector (labeled J12 in the service manual) from the motherboard. Carefully remove the speaker cable connector (labeled J12 in the service manual) from the motherboard. Carefully remove the speaker cable connector (labeled J12 in the service manual) from the motherboard.
    • Carefully remove the speaker cable connector (labeled J12 in the service manual) from the motherboard.
  32. Lift the ZIF collar securing the power button cable (labeled J6 in the service manual) with the flat end of a spudger to loosen its grip. Pull the power button cable straight up from its socket. Pull the power button cable straight up from its socket.
    • Lift the ZIF collar securing the power button cable (labeled J6 in the service manual) with the flat end of a spudger to loosen its grip.
    • Pull the power button cable straight up from its socket.
  33. Remove the smart-battery cable connector from its socket (labeled J34 in the service manual). Remove the smart-battery cable connector from its socket (labeled J34 in the service manual). Remove the smart-battery cable connector from its socket (labeled J34 in the service manual).
    • Remove the smart-battery cable connector from its socket (labeled J34 in the service manual).
  34. Pinch the battery power connector and lift straight up to unclip it from its socket on the motherboard (labeled J29 in the service manual). Pinch the battery power connector and lift straight up to unclip it from its socket on the motherboard (labeled J29 in the service manual). Pinch the battery power connector and lift straight up to unclip it from its socket on the motherboard (labeled J29 in the service manual).
    • Pinch the battery power connector and lift straight up to unclip it from its socket on the motherboard (labeled J29 in the service manual).
  35. Use the flat end of a spudger to separate the battery supply cable connector bracket from the socket (labeled J30 in the service manual). Pull the battery supply cable connector straight up from the board.
    • Use the flat end of a spudger to separate the battery supply cable connector bracket from the socket (labeled J30 in the service manual).
    • Pull the battery supply cable connector straight up from the board.
  36. Carefully pull the LCD flex cable straight up from its socket in the motherboard (labeled J48 in the service manual). Carefully pull the LCD flex cable straight up from its socket in the motherboard (labeled J48 in the service manual).
    • Carefully pull the LCD flex cable straight up from its socket in the motherboard (labeled J48 in the service manual).
  37. Remove the eight Phillips #1 screws from the motherboard. The screw securing the ethernet cable bracket has a washer between it and the bracket. Take care not to lose it.
    • Remove the eight Phillips #1 screws from the motherboard.
    • The screw securing the ethernet cable bracket has a washer between it and the bracket. Take care not to lose it.
  38. Lift the motherboard from the light-bar side and pull it toward the edge of the case to free the ethernet cable connector from under the case. Lift the motherboard out of the case to gain access to the ethernet cable connector. Do not attempt to remove the board entirely as it is still connected to the monitor.
    • Lift the motherboard from the light-bar side and pull it toward the edge of the case to free the ethernet cable connector from under the case.
    • Lift the motherboard out of the case to gain access to the ethernet cable connector.
    • Do not attempt to remove the board entirely as it is still connected to the monitor.
  39. Remove the ethernet cable connector (labeled J11 in the service manual) from the mother board. Remove the ethernet cable connector (labeled J11 in the service manual) from the mother board.
    • Remove the ethernet cable connector (labeled J11 in the service manual) from the mother board.
  40. Remove the two Phillips #2 side housing screws from the bottom housing. There are holes above the screws into which you may insert a standard size screwdriver to unscrew them.
    • Remove the two Phillips #2 side housing screws from the bottom housing.
    • There are holes above the screws into which you may insert a standard size screwdriver to unscrew them.
  41. Remove the single Phillips #2 screw from the bottom housing near the speaker grille.
    • Remove the single Phillips #2 screw from the bottom housing near the speaker grille.
  42. Remove the bottom housing. Remove the bottom housing.
    • Remove the bottom housing.
  43. Remove the ethernet cable, or simply tuck it out of the way. Remove the ethernet cable, or simply tuck it out of the way.
    • Remove the ethernet cable, or simply tuck it out of the way.
  44. Remove the light-bar cable from the LCD bracket and move it out of the way. During reassembly, refer to the third image for tape and cable replacement. During reassembly, refer to the third image for tape and cable replacement.
    • Remove the light-bar cable from the LCD bracket and move it out of the way.
    • During reassembly, refer to the third image for tape and cable replacement.
  45. Remove any tape from the LCD cable connector. For reassembly, refer to the third image for tape and cable replacement. For reassembly, refer to the third image for tape and cable replacement.
    • Remove any tape from the LCD cable connector.
    • For reassembly, refer to the third image for tape and cable replacement.
  46. Pull the LCD cable connector, firmly and evenly, straight out of its socket. Pull the LCD cable connector, firmly and evenly, straight out of its socket.
    • Pull the LCD cable connector, firmly and evenly, straight out of its socket.
  47. Remove the four Phillips #2 screws from the LCD bracket.
    • Remove the four Phillips #2 screws from the LCD bracket.
  48. Remove the LCD bracket. Remove the LCD bracket.
    • Remove the LCD bracket.
  49. Use the flat end of a spudger to lift the LCD out of the rubber gasket frame. Use the flat end of a spudger to lift the LCD out of the rubber gasket frame.
    • Use the flat end of a spudger to lift the LCD out of the rubber gasket frame.
  50. Remove the LCD from the front housing. Remove the LCD from the front housing.
    • Remove the LCD from the front housing.
Conclusión
Sam Lionheart
Miembro Desde 18/10/12
367,447 Reputación
537 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
104 Miembros
8,413 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 536
