Introducción
Do you know when it’s time to change the batteries in your Weiser lock? Here are some hints:
- Your electronic lock flashes red.
- Your keypad doesn’t light up.
- If you have a home security provider, they’ll probably let you know!
In this guide, you will learn how to change the batteries of your Weiser Smartcode 10 Touchscreen Electronic Lock.
(Try saying that ten times fast!)
Before starting this guide, make sure all home security connected to the door lock is disarmed. Let’s begin!
Herramientas
Partes
No se especificaron partes.
Unlock your door and open it.
Make sure the bolt/latch is fully inside the door before you continue.
Congratulations! Make sure to redo this process each year to ensure your device continues to work!
Una persona más ha completado esta guía.
