Saltar al contenido principal
Weinmann VENTImotion and VENTIlogic Display Board Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Weinmann VENTImotion and VENTIlogic Display Board Replacement, Display Board: paso 1, imagen 1 de 2 Weinmann VENTImotion and VENTIlogic Display Board Replacement, Display Board: paso 1, imagen 2 de 2
    • Open the device by following these steps:
    • Place the device on a non-slip surface with the top facing downwards
    • Remove the filter cassette from the top part of the housing.
    • Undo and remove the 6 screws (34).
    • Open the bottom of the housing (35) away to the side.
    • Undo the connecting cables for the humidifier (42) and the alarm (43).
    • Make sure the power supply plug is disconnected.
  2. Weinmann VENTImotion and VENTIlogic Display Board Replacement: paso 3, imagen 1 de 1
    • Disconnect the following:
    • encoder connector (82).
    • connectors of interfaces (84) and (85) off the control board.
  3. Weinmann VENTImotion and VENTIlogic Display Board Replacement: paso 4, imagen 1 de 1
    • Disconnect the ribbon cable of the display and the fascia film.
    • Pull the latch out until you feel resistance. You can then pull out the ribbon cable.
    • If the latch has not been opened correctly, the ribbon cable may be damaged when it is pulled out.
  4. Weinmann VENTImotion and VENTIlogic Display Board Replacement: paso 5, imagen 1 de 1
    • Pull flow measurement hoses (56) off the flow sensor.
    • Pull pressure measurement hoses (57) off the pressure sensors.
  5. Weinmann VENTImotion and VENTIlogic Display Board Replacement: paso 6, imagen 1 de 1
    • Undo the four screws (51) and remove control board (50).
  6. Weinmann VENTImotion and VENTIlogic Display Board Replacement: paso 7, imagen 1 de 1
    • Remove spring (54) from the control board and remove battery (52) (see "7.9 Replace battery on control board" on page 42).
    • Remove display
  7. Weinmann VENTImotion and VENTIlogic Display Board Replacement: paso 9, imagen 1 de 1
    • Insert a new display (49).
    • The display may not tilt and must be straight in the guides.
Conclusión
Cameron Young
Miembro Desde 04/22/19
174 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G19, Paton Spring 2020 Miembro de Cal Poly, Team S7-G19, Paton Spring 2020
CPSU-PATON-S20S7G19
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 89
