Saltar al contenido principal
Water Damage on main board of Nokia 206 RM873
Qué necesitas
  1. Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: paso 1, imagen 1 de 3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: paso 1, imagen 2 de 3 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: paso 1, imagen 3 de 3
    • Remove back cover & battery.
  2. Water Damage on main board of Nokia 206 RM873: paso 2, imagen 1 de 2 Water Damage on main board of Nokia 206 RM873: paso 2, imagen 2 de 2
    • Remove the front case by prying it open. You will hear clicks.
    • Be careful with taking off screen if you use a spudger.
  3. Water Damage on main board of Nokia 206 RM873: paso 3, imagen 1 de 2 Water Damage on main board of Nokia 206 RM873: paso 3, imagen 2 de 2
    • Use a Torx screwdriver to remove the screen screws.
    • Use a spudger or tweezers to remove the connector of the LCD screen.
  4. Water Damage on main board of Nokia 206 RM873: paso 4, imagen 1 de 3 Water Damage on main board of Nokia 206 RM873: paso 4, imagen 2 de 3 Water Damage on main board of Nokia 206 RM873: paso 4, imagen 3 de 3
    • Remove keyboard by prying it open with a spudger.
    • The keyboard is secured with adhesive, be careful!
  5. Water Damage on main board of Nokia 206 RM873: paso 5, imagen 1 de 3 Water Damage on main board of Nokia 206 RM873: paso 5, imagen 2 de 3 Water Damage on main board of Nokia 206 RM873: paso 5, imagen 3 de 3
    • The PCB board had water damage, see this in picture 3.
    • To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
  6. Water Damage on main board of Nokia 206 RM873: paso 6, imagen 1 de 2 Water Damage on main board of Nokia 206 RM873: paso 6, imagen 2 de 2
    • How and where to use the cotton swabs.
Conclusión
16 personas más completaron esta guía.
Kevin D
Miembro Desde 05/02/14
7,276 Reputación
21 Guías creadas
4 comentarios
no use .it is not switching on . replaced with good batter also. no on
nabhan75 - Contestar
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Kevin D - Contestar
Nokia 206 display and charger pin
Mithilesh Yadav - Contestar
Not working kiy 1.2.3 and colling ricev kiy not working
K .M Jugesh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 10,765
