Introducción
Located on the back panel of the burner are four rubber stoppers on each corner. Be sure to have remove to back panel before beginning and be careful to not lose the small nuts and washers holding the screws in place.
Qué necesitas
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
The screws in the rubber legs of the burner do not need to be removed.
While using the wrench to hold the bolt, use the screwdriver to remove the screw.
The leg is two separate pieces, the plastic leg and rubber stopper.
