Saltar al contenido principal
Waring Pro SB30 Indicator Lights Replacement
Qué necesitas
  1. Waring Pro SB30 Indicator Lights Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Indicator Lights Replacement: paso 2, imagen 1 de 2 Waring Pro SB30 Indicator Lights Replacement: paso 2, imagen 2 de 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Indicator Lights Replacement: paso 3, imagen 1 de 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Indicator Lights Replacement, Indicator Lights: paso 4, imagen 1 de 1
    • Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
  5. Waring Pro SB30 Indicator Lights Replacement: paso 5, imagen 1 de 2 Waring Pro SB30 Indicator Lights Replacement: paso 5, imagen 2 de 2
    • Push the screwdrivers inward and guide the bulb outwards.
    • Gently grab by the wires and remove bulb from plastic shell.
Conclusión
Sun Fai Lau
Miembro Desde 09/22/14
588 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 10-7, Brown Fall 2014 Miembro de USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 314
