Saltar al contenido principal
Waring 51BL29 Switch Replacement
Qué necesitas
  1. Waring 51BL29 Switch Replacement, Bottom Panel: paso 1, imagen 1 de 2 Waring 51BL29 Switch Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Switch Replacement: paso 2, imagen 1 de 1
    • Remove the bottom panel.
  3. Waring 51BL29 Switch Replacement, Drive Coupling: paso 3, imagen 1 de 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Switch Replacement: paso 4, imagen 1 de 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Switch Replacement: paso 5, imagen 1 de 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Switch Replacement, Motor: paso 6, imagen 1 de 2 Waring 51BL29 Switch Replacement, Motor: paso 6, imagen 2 de 2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Switch Replacement: paso 7, imagen 1 de 1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Switch Replacement: paso 8, imagen 1 de 3 Waring 51BL29 Switch Replacement: paso 8, imagen 2 de 3 Waring 51BL29 Switch Replacement: paso 8, imagen 3 de 3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
  9. Waring 51BL29 Switch Replacement, Switch: paso 9, imagen 1 de 1
    • Once you have the motor and switch by themselves it should look like this.
  10. Waring 51BL29 Switch Replacement: paso 10, imagen 1 de 2 Waring 51BL29 Switch Replacement: paso 10, imagen 2 de 2
    • Separate the zip-tie holding the wires to the motor.
  11. Waring 51BL29 Switch Replacement: paso 11, imagen 1 de 1
    • Now the switch is separated from the motor and blender frame.
Conclusión
Dean Becker
Miembro Desde 04/17/17
470 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S15-G4, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 691
