Saltar al contenido principal
Waring 51BL29 Motor Replacement
Qué necesitas
  1. Waring 51BL29 Motor Replacement, Bottom Panel: paso 1, imagen 1 de 2 Waring 51BL29 Motor Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Motor Replacement: paso 2, imagen 1 de 1
    • Remove the bottom panel.
  3. Waring 51BL29 Motor Replacement, Drive Coupling: paso 3, imagen 1 de 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Motor Replacement: paso 4, imagen 1 de 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Motor Replacement: paso 5, imagen 1 de 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Motor Replacement, Motor: paso 6, imagen 1 de 2 Waring 51BL29 Motor Replacement, Motor: paso 6, imagen 2 de 2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Motor Replacement: paso 7, imagen 1 de 1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Motor Replacement: paso 8, imagen 1 de 3 Waring 51BL29 Motor Replacement: paso 8, imagen 2 de 3 Waring 51BL29 Motor Replacement: paso 8, imagen 3 de 3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
Conclusión
Dean Becker
Miembro Desde 04/17/17
470 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S15-G4, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 Miembros
5 Guías creadas
Un comentario
Hi
Where do I source a replacement motor? I have been looking without success for UK supplier. Thanks Jill
I have a much loved Vintage Waring blender …
Jill Lancaster - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 2,547
