Saltar al contenido principal
Wahl Lithium Ion 5537C Blade Replacement
Qué necesitas
  1. Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: paso 1, imagen 1 de 2 Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: paso 1, imagen 2 de 2
    • Take out the batteries by pulling off the cover from the back and once done put the cover back on.
  2. Wahl Lithium Ion 5537C Blade Replacement: paso 2, imagen 1 de 3 Wahl Lithium Ion 5537C Blade Replacement: paso 2, imagen 2 de 3 Wahl Lithium Ion 5537C Blade Replacement: paso 2, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the two screws on the blade and place them in the container.
    • Detach the blade from the body of the shaver and also remove the blade supporting mounts.
  3. Wahl Lithium Ion 5537C Blade Replacement: paso 3, imagen 1 de 3 Wahl Lithium Ion 5537C Blade Replacement: paso 3, imagen 2 de 3 Wahl Lithium Ion 5537C Blade Replacement: paso 3, imagen 3 de 3
    • Grab the replacement new blade and before mounting the support mount clean it with the cleaning brush to remove any dirt.
    • Place the supporting mount back to the new blade making sure it is properly attached.
  4. Wahl Lithium Ion 5537C Blade Replacement: paso 4, imagen 1 de 3 Wahl Lithium Ion 5537C Blade Replacement: paso 4, imagen 2 de 3 Wahl Lithium Ion 5537C Blade Replacement: paso 4, imagen 3 de 3
    • Place the blade with mount attached to the trimmer such that the screw holes are visible through
    • Grab on the blade hard and torque both screws one by one.
    • Check if the blade is attached tightly to the trimmer.
    • Insert the batteries inside the trimmer and start using!
Conclusión
Una persona más ha completado esta guía.
Osman Saeed
Miembro Desde 07/11/21
109 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 40
Todo El Tiempo: 1,082
