Saltar al contenido principal
Wahl Chrome Pro Power Cord Replacement
Qué necesitas
  1. Wahl Chrome Pro Power Cord Replacement, Case: paso 1, imagen 1 de 1
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Power Cord Replacement: paso 2, imagen 1 de 1
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Power Cord Replacement: paso 3, imagen 1 de 1
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Power Cord Replacement: paso 4, imagen 1 de 1
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Power Cord Replacement: paso 5, imagen 1 de 1
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Power Cord Replacement: paso 6, imagen 1 de 1
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Power Cord Replacement: paso 7, imagen 1 de 1
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Power Cord Replacement: paso 8, imagen 1 de 1
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Power Cord Replacement, Power Cord: paso 9, imagen 1 de 2 Wahl Chrome Pro Power Cord Replacement, Power Cord: paso 9, imagen 2 de 2
    • Remove one 7.5 mm JIS #1 screw from the switch base.
  10. Wahl Chrome Pro Power Cord Replacement: paso 10, imagen 1 de 1
    • Unplug the cord terminal from the motor connector.
  11. Wahl Chrome Pro Power Cord Replacement: paso 11, imagen 1 de 1
    • Remove the cord from the device base by pulling gently.
Conclusión
Manuel Salazar M.
Miembro Desde 11/07/17
101 Reputación
1 Guía escrita
Equipo
IUPUI, Team S7-G3, Baechle Fall 2017 Miembro de IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 768
