Saltar al contenido principal
Wacom Intuos4 Foam Safety Pad Replacement
Qué necesitas
  1. Wacom Intuos4 Foam Safety Pad Replacement, Casing: paso 1, imagen 1 de 3 Wacom Intuos4 Foam Safety Pad Replacement, Casing: paso 1, imagen 2 de 3 Wacom Intuos4 Foam Safety Pad Replacement, Casing: paso 1, imagen 3 de 3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Foam Safety Pad Replacement: paso 2, imagen 1 de 2 Wacom Intuos4 Foam Safety Pad Replacement: paso 2, imagen 2 de 2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Foam Safety Pad Replacement, Foam Safety Pad: paso 3, imagen 1 de 1
    • Use a spudger to safely remove the white and sliver pad without applying enough pressure to scratch the motherboard.
Conclusión
Aidan Sullivan
Miembro Desde 10/26/22
293 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Miembro de UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 139
