Saltar al contenido principal
Wacom Intuos4 Express Keys Replacement
Qué necesitas
  1. Wacom Intuos4 Express Keys Replacement, Casing: paso 1, imagen 1 de 3 Wacom Intuos4 Express Keys Replacement, Casing: paso 1, imagen 2 de 3 Wacom Intuos4 Express Keys Replacement, Casing: paso 1, imagen 3 de 3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Express Keys Replacement: paso 2, imagen 1 de 2 Wacom Intuos4 Express Keys Replacement: paso 2, imagen 2 de 2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Express Keys Replacement, Express Keys: paso 3, imagen 1 de 3 Wacom Intuos4 Express Keys Replacement, Express Keys: paso 3, imagen 2 de 3 Wacom Intuos4 Express Keys Replacement, Express Keys: paso 3, imagen 3 de 3
    • Lift yellow tape covering the flat wires with a pair of tweezers.
    • Lift the black plastic clip holding the flat wire to the connector.
    • This should be done with a plastic tool to avoid damaging the contacts.
    • Pull on the white plastic tab to disconnect the flat wire.
    • Do this for the left and right express key chips.
  4. Wacom Intuos4 Express Keys Replacement: paso 4, imagen 1 de 1
    • Pull the black plastic clip away from the flat wire connector, and pull the flat wire out.
    • It may be easier to pull with a tool on one side, and with your hand on the other at the same time.
  5. Wacom Intuos4 Express Keys Replacement: paso 5, imagen 1 de 1
    • Use a #1 Phillips head screwdriver to unscrew the four 5mm screws on the express key board you want to replace.
  6. Wacom Intuos4 Express Keys Replacement: paso 6, imagen 1 de 2 Wacom Intuos4 Express Keys Replacement: paso 6, imagen 2 de 2
    • Lift the board and rubber buttons up from the case.
    • Separate the rubber buttons from the board.
Conclusión
Aidan Sullivan
Miembro Desde 10/26/22
293 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Miembro de UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 202
