Saltar al contenido principal
Wacom Intuos Pro Touch Pad Replacement
Qué necesitas
  1. Wacom Intuos Pro Touch Pad Replacement, Battery: paso 1, imagen 1 de 3 Wacom Intuos Pro Touch Pad Replacement, Battery: paso 1, imagen 2 de 3 Wacom Intuos Pro Touch Pad Replacement, Battery: paso 1, imagen 3 de 3
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Touch Pad Replacement: paso 2, imagen 1 de 3 Wacom Intuos Pro Touch Pad Replacement: paso 2, imagen 2 de 3 Wacom Intuos Pro Touch Pad Replacement: paso 2, imagen 3 de 3
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
  3. Wacom Intuos Pro Touch Pad Replacement: paso 3, imagen 1 de 2 Wacom Intuos Pro Touch Pad Replacement: paso 3, imagen 2 de 2
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Touch Pad Replacement: paso 4, imagen 1 de 2 Wacom Intuos Pro Touch Pad Replacement: paso 4, imagen 2 de 2
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Touch Pad Replacement: paso 5, imagen 1 de 2 Wacom Intuos Pro Touch Pad Replacement: paso 5, imagen 2 de 2
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
  6. Wacom Intuos Pro Touch Pad Replacement, Touch Pad: paso 6, imagen 1 de 1
    • Gently pull the blue tabs on the four ribbon cables from the ZIF connectors on the motherboard.
  7. Wacom Intuos Pro Touch Pad Replacement: paso 7, imagen 1 de 1
    • Remove the five 4.5mm screws using a Phillips #00 screwdriver.
  8. Wacom Intuos Pro Touch Pad Replacement: paso 8, imagen 1 de 2 Wacom Intuos Pro Touch Pad Replacement: paso 8, imagen 2 de 2
    • Gently wedge the Jimmy under the black backing of the blue touchpad.
    • Gently pry up the touchpad and remove it from the case.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 34
Todo El Tiempo: 1,238
