Introducción
The motherboard is responsible for all the processing required to turn the touch input from the touchpad into the digital drawing produced on the screen. If you are having any glitches or issues with the functionality of your device, this guide will show you how to replace the motherboard in the Wacom Intuos Pro. The motherboard also houses the charging port, so a replacement of this component may alleviate an inability to charge in your device.
You will need to be able to use a soldering iron to complete this guide, so please refer to this soldering guide for help.
Qué necesitas
Orient the device so the bottom casing is facing upwards.
Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
