Introducción
If you begin to notice that your battery doesn’t seem to be charging, or isn’t holding a charge like it used to, then it may be time to replace it. This guide will walk you through the steps to replace the battery in your Wacom Intuos Pro. Replacing the battery of your device should restore its charge capacity and lifespan to near new conditions.
Qué necesitas
Orient the device so the bottom casing is facing upwards.
Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
2 personas más completaron esta guía.
5 comentarios
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Has anyone got a lint to the replacement battery?
PTH-660 works fine without the battery, just remove it and use it with USB cable
Where can I find a replacement battery for this model?
