Introducción
If you need to replace a Brad Nailer Pressure Regulator Knob, follow the steps outlined in this guide. For this guide, you will need a 2mm Allen wrench. The steps outlined are relatively easy to follow.
Herramientas
Partes
No se requieren partes.
  1. Using a 2mm Allen wrench, remove the Allen screw located on the pressure regulator knob on the back of the brad nailer.
    • Using a 2mm Allen wrench, remove the Allen screw located on the pressure regulator knob on the back of the brad nailer.
  2. Remove the knob from the gun and replace the knob.
    • Remove the knob from the gun and replace the knob.
    • Be aware of the rubber spacer that will come off with the knob; when you replace the knob put the spacer back in the middle around the screw hole.
Conclusión
Ousman Jammeh
Miembro Desde 17/09/18
507 Reputación
3 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 27
