Introducción
If you need to replace a Brad Nailer Pressure Regulator Chamber Gasket, follow the steps outlined in this guide. For this guide, you will need a 4mm Allen wrench. The steps outlined are relatively easy to follow.
Partes
No se requieren partes.
  1. Using a 4mm Allen wrench, remove the 4 Allen screws, 44mm in length, from the yellow cap on the back of the brad nailer.
    • Using a 4mm Allen wrench, remove the 4 Allen screws, 44mm in length, from the yellow cap on the back of the brad nailer.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the yellow cap to reveal the gasket.
    • Remove the yellow cap to reveal the gasket.
    • Keep the nailer upright so the piston does not fall out. If the piston falls out, simply put it back in place.
  4. Remove the faulty gasket and replace it with a new gasket.
    • Remove the faulty gasket and replace it with a new gasket.
Conclusión
Una persona más ha completado esta guía.
Ousman Jammeh
Miembro Desde 17/09/18
507 Reputación
3 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 62
