Saltar al contenido principal
Introducción
If you need to replace a Brad Nailer Male Air Compressor Adapter Gasket, follow the steps outlined in this guide. For this guide, you will need a crescent wrench and flathead screwdriver. The steps outlined are relatively easy to follow.
Partes
No se especificaron partes.
  1. Using a crescent wrench, loosen the yellow nut located between the grip and the male air compressor adapter.
    • Using a crescent wrench, loosen the yellow nut located between the grip and the male air compressor adapter.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Remove the yellow component.
    • Remove the yellow component.
  4. Use a spudger to pry the gasket from the base of the threads. Use a spudger to pry the gasket from the base of the threads.
    • Use a spudger to pry the gasket from the base of the threads.
Conclusión
Ousman Jammeh
Miembro Desde 17/09/18
507 Reputación
3 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 41
