Saltar al contenido principal
Vulcan Venture II VNB14002IE Speaker Replacement
Qué necesitas
  1. Vulcan Venture II VNB14002IE Speaker Replacement, Back Panel: paso 1, imagen 1 de 1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE Speaker Replacement: paso 2, imagen 1 de 1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Locate the speaker modules on the back of the laptop.
    • Gently pry the speakers out of the plastic casing using your finger or the blue plastic pry tool.
  4. Vulcan Venture II VNB14002IE Speaker Replacement: paso 4, imagen 1 de 1
    • Gently pull out the speaker wire connector from the motherboard.
  5. Vulcan Venture II VNB14002IE Speaker Replacement: paso 5, imagen 1 de 1
    • Unwrap the wires from their holders and remove the speaker modules.
    • When re-inserting the speakers, make sure the wires are correctly wrapped around the plastic holders, and that the speaker wire goes underneath the touch pad connector wire, as it was before.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 324
