Saltar al contenido principal
Vulcan Venture II VNB14002IE Motherboard Replacement
Qué necesitas
  1. Vulcan Venture II VNB14002IE Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE Motherboard Replacement: paso 2, imagen 1 de 1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Disconnect the 4 ribbon cables connected to the motherboard by carefully lifting up the black bar attached to the housing. Slowly slide the cable out once released.
    • Disconnect the wire connected to the motherboard.
    • Disconnect the battery by gently pulling out the cable connected to the board.
  4. Vulcan Venture II VNB14002IE Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the screws located in the corners of the board using a J00 screwdriver.
  5. Vulcan Venture II VNB14002IE Motherboard Replacement: paso 5, imagen 1 de 1
    • Gently lift the board out of the housing without any cables still connected to the board.
    • Picture shows the housing of the motherboard after the motherboard has been removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 427
