Saltar al contenido principal
Vulcan Venture II VNB14002IE I/O Board Replacement
Qué necesitas
  1. Vulcan Venture II VNB14002IE I/O Board Replacement, Back Panel: paso 1, imagen 1 de 1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE I/O Board Replacement: paso 2, imagen 1 de 1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE I/O Board Replacement, I/O Board: paso 3, imagen 1 de 1
    • Locate the IO board on the back panel.
  4. Vulcan Venture II VNB14002IE I/O Board Replacement: paso 4, imagen 1 de 2 Vulcan Venture II VNB14002IE I/O Board Replacement: paso 4, imagen 2 de 2
    • Locate the ribbon connector on the IO board, and lift the black bar closest the the ribbon.
    • Pull the ribbon cable away from the connector, releasing it.
  5. Vulcan Venture II VNB14002IE I/O Board Replacement: paso 5, imagen 1 de 2 Vulcan Venture II VNB14002IE I/O Board Replacement: paso 5, imagen 2 de 2
    • Locate the screws on the IO panel, and use the J00+ bit to unscrew them.
  6. Vulcan Venture II VNB14002IE I/O Board Replacement: paso 6, imagen 1 de 1
    • The IO Board is now safe to remove from the computer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 511
