Saltar al contenido principal
Vulcan Venture II Battery Replacement
Qué necesitas
  1. Vulcan Venture II Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II Battery Replacement: paso 2, imagen 1 de 1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Use a J00 screwdriver to unscrew the 4 battery screws .
  4. Vulcan Venture II Battery Replacement: paso 4, imagen 1 de 1
    • Remove the black adhesive strip covering the battery connector.
  5. Vulcan Venture II Battery Replacement: paso 5, imagen 1 de 1
    • Gently remove the battery connector by slowly applying pressure on the connector in the direction of the battery.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 1,097
