Saltar al contenido principal
Vtech Touch and Swipe Baby Phone Power Switch Replacement
Qué necesitas
  1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: paso 1, imagen 1 de 2 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: paso 1, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 2, imagen 1 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 2, imagen 2 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 2, imagen 3 de 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 3, imagen 1 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 3, imagen 2 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 3, imagen 3 de 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: paso 4, imagen 1 de 2 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: paso 4, imagen 2 de 2
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 5, imagen 1 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 5, imagen 2 de 3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: paso 5, imagen 3 de 3
    • Lift directly up to remove the switch and lay the wire down to the side.
    • Once the switch has been taken out you can remove the switch's casing.
Conclusión
Una persona más ha completado esta guía.
tellocordova
Miembro Desde 09/04/15
342 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-4, Sullivan Fall 2015 Miembro de USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Miembros
12 Guías creadas
2 comentarios
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
Schwarzstein - Contestar
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 627
