Saltar al contenido principal
Vtech Innotab 3 Speaker Replacement
Qué necesitas
  1. Vtech Innotab 3 Speaker Replacement, Rear Panel: paso 1, imagen 1 de 3 Vtech Innotab 3 Speaker Replacement, Rear Panel: paso 1, imagen 2 de 3 Vtech Innotab 3 Speaker Replacement, Rear Panel: paso 1, imagen 3 de 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Speaker Replacement: paso 3, imagen 1 de 3 Vtech Innotab 3 Speaker Replacement: paso 3, imagen 2 de 3 Vtech Innotab 3 Speaker Replacement: paso 3, imagen 3 de 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Speaker Replacement: paso 4, imagen 1 de 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Speaker Replacement, Speaker: paso 5, imagen 1 de 3 Vtech Innotab 3 Speaker Replacement, Speaker: paso 5, imagen 2 de 3 Vtech Innotab 3 Speaker Replacement, Speaker: paso 5, imagen 3 de 3
    • After you disassemble the device, put the back panel to the side and move your attention to the front piece.
    • Remove the four screws using a PH00 screwdriver.
  6. Vtech Innotab 3 Speaker Replacement: paso 6, imagen 1 de 2 Vtech Innotab 3 Speaker Replacement: paso 6, imagen 2 de 2
    • Using a nylon or metal spudger, lift the blue plastic piece upwards.
    • Keeping the plastic piece lifted, carefully pinch the edge of the speaker and remove it.
    • Be sure not to tug on the speaker too violently to prevent tearing a wiring from its solder.
  7. Vtech Innotab 3 Speaker Replacement: paso 7, imagen 1 de 3 Vtech Innotab 3 Speaker Replacement: paso 7, imagen 2 de 3 Vtech Innotab 3 Speaker Replacement: paso 7, imagen 3 de 3
Conclusión
Zach Diviney
Miembro Desde 03/11/15
419 Reputación
4 Guías creadas
Equipo
Colorado Springs, Team 5-4, Panko Spring 2015 Miembro de Colorado Springs, Team 5-4, Panko Spring 2015
UCCS-PANKO-S15S5G4
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 643
