Saltar al contenido principal
Vtech Innotab 3 Headphone Port Replacement
Qué necesitas
  1. Vtech Innotab 3 Headphone Port Replacement, Rear Panel: paso 1, imagen 1 de 3 Vtech Innotab 3 Headphone Port Replacement, Rear Panel: paso 1, imagen 2 de 3 Vtech Innotab 3 Headphone Port Replacement, Rear Panel: paso 1, imagen 3 de 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Headphone Port Replacement: paso 2, imagen 1 de 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Headphone Port Replacement: paso 3, imagen 1 de 3 Vtech Innotab 3 Headphone Port Replacement: paso 3, imagen 2 de 3 Vtech Innotab 3 Headphone Port Replacement: paso 3, imagen 3 de 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Headphone Port Replacement: paso 4, imagen 1 de 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Headphone Port Replacement, Headphone Port: paso 5, imagen 1 de 3 Vtech Innotab 3 Headphone Port Replacement, Headphone Port: paso 5, imagen 2 de 3 Vtech Innotab 3 Headphone Port Replacement, Headphone Port: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • On the front panel of the device, the headphone poet is located at the bottom right corner of the device, opposte of the speaker.
    • Using tweezers, lift up to remove the headphone port from its holding.
    • Be careful not to tug too hard when removing the headphone port for you may disconnect the wires from the solder
  6. Vtech Innotab 3 Headphone Port Replacement: paso 6, imagen 1 de 3 Vtech Innotab 3 Headphone Port Replacement: paso 6, imagen 2 de 3 Vtech Innotab 3 Headphone Port Replacement: paso 6, imagen 3 de 3
    • Use tweezers to hold the four connecting wires away from the headphone port.
    • Desolder the four wires connected to the headphone port.
    • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
Conclusión
Una persona más ha completado esta guía.
Zach Diviney
Miembro Desde 03/11/15
419 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 277
