Saltar al contenido principal
Vtech InnoTab 3S Screen Replacement
Qué necesitas
  1. Vtech InnoTab 3S Screen Replacement, Rear Panel: paso 1, imagen 1 de 3 Vtech InnoTab 3S Screen Replacement, Rear Panel: paso 1, imagen 2 de 3 Vtech InnoTab 3S Screen Replacement, Rear Panel: paso 1, imagen 3 de 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Screen Replacement: paso 2, imagen 1 de 2 Vtech InnoTab 3S Screen Replacement: paso 2, imagen 2 de 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Screen Replacement: paso 3, imagen 1 de 3 Vtech InnoTab 3S Screen Replacement: paso 3, imagen 2 de 3 Vtech InnoTab 3S Screen Replacement: paso 3, imagen 3 de 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Screen Replacement: paso 4, imagen 1 de 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Screen Replacement, Motherboard: paso 5, imagen 1 de 2 Vtech InnoTab 3S Screen Replacement, Motherboard: paso 5, imagen 2 de 2
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S Screen Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S Screen Replacement, Screen: paso 7, imagen 1 de 3 Vtech InnoTab 3S Screen Replacement, Screen: paso 7, imagen 2 de 3 Vtech InnoTab 3S Screen Replacement, Screen: paso 7, imagen 3 de 3
    • Open the clip holding the screen plug with the yellow film.
    • The clip securing the screen is located at the top of the motherboard.
    • Remove all seven of the 5mm screws on the motherboard to separate the motherboard from the screen.
  8. Vtech InnoTab 3S Screen Replacement: paso 8, imagen 1 de 2 Vtech InnoTab 3S Screen Replacement: paso 8, imagen 2 de 2
    • Avoid forceful movements when separating the screen from the motherboard.
    • Carefully separate the motherboard from the device screen. Replace the damaged screen with an operational one.
Conclusión
Karina Garcia
Miembro Desde 08/30/15
830 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 8-2, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Miembros
9 Guías creadas
4 comentarios
What is the part number for the screen. Where can I buy one. Thank you.
david goodwin - Contestar
what is the size of the screen
Adrienne Dooms - Contestar
My grandson dropped his innotab 3 and now the screen is all scrambled. Can this be fixed? It did not crack the screen.
charma1963 - Contestar
Where can I buy the replacement screen for the Vtech innotab 3S
Michael Kurrus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 2,224
